Old 21-Sep-2012, 11:37 PM   #11
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for reception of the Digital broadcast tv channels.
The ANT751 is designed to receive channels 7 thru 51. And as such is Not the antenna for your reception situation.
You location has receivable Digital Tv stations/channels in all 3 Tv bands of ,
VHF low band channels , 2 thru 6.
VHF high band channels , 7 thru 13.
UHF band channels 14 thru 51.
Install a All channel antenna. The HD7000R is a All Channel antenna and as such is designed to receive all the channels , 2 thru 51.
Above the roof install a Winegard HD7000R antenna aimed at about 140 degree magnetic compass direction.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or kind.
The Tv's Must channel scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
