Old 21-Sep-2012, 10:16 PM   #6
The Digital Tv stations/channels are strong at your location.
Install a ANT751 so the antenna can be aimed at about 330 degree magnetic compass direction.
The ANT751 can be on the south end of the house , however the ANT751 MUST be mounted UP high in a manner that the roof is not blocking reception to the , north west , north , south east.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing.html.
The Digital Tv stations/channels are to the , north west , north , south east.
The ANT751 receives good at the front and front angles and back and back angles.
The ANT751 will receive the Strong Tv transmissions to the , north west , north , south east.
For 1 Tv connection use no splitter , use no antenna amplifier.
For 2 Tv's connected use a common simple 2 way splitter , use no antenna amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to install the ANT751 at a location that has the least amount to no amount of obstructions of any type or kind.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channel' or Antenna Channels' in the Tv setup menu because the the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Do not channel scan for cable tv channels.
Here are places to buy antennas and etc. , http://www.solidsignal.com, http://www.amazon.com , http://www.channelmasterstore.com
Last edited by GroundUrMast; 5-Nov-2012 at 9:40 AM. Reason: Deleting off-topic content
