Old 9-Oct-2010, 12:51 AM   #5
the_other_one
Originally Posted by dovesong View Post
Ok, so that means the "real" channels I want to receive are 10 (ABC) and 39 (MyN).
Since NBC is broadcast on real channel 11, that means the Channel Master JoinTenna would not be a good solution to catch ABC, right? But, as Tower Guy suggests, I could use a UVSJ for ABC and maybe a Jointenna for MyN? That solution would still require a total of three antennas, though... any better options out there?
Thanks again!
dovesong,
I don't think you need to worry about NBC on RF11 as you already listed WVIT NBC 30.1 (RF35).
I have seen the TERK HDTVi recommended. It is an indoor UHF VHF combo that is un-amplified (based on your strong signals I believe you want to avoid amplification). If you can buy it from a place you can return it (Amazon?) then it would be worth trying.
the_other_one
the_other_one is offline   Reply With Quote
