Old 21-Sep-2012, 3:25 PM   #3
signals unlimited
Simple, effective DTV reception solutions
The mount on the South side of your home is of no value unless you can see over the top to face the North.
You can use the vent mount with a Terk HDTVo antenna pointing to 350 degrees magnetic.
A better option would be an RCA ANT751 antenna pointed to 350. It could be mount anywhere on the North side of your home, on anything over 12-15 feet off the ground and a clear view to the North.
To hook up four sets use a Channel Master 3414 distribution amplifier.
