Old 21-Sep-2012, 8:34 AM   #2
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a teleview recommendation for digital broadcast Tv reception.
It looks like ,
KRMV-LP channel 45 , if the station is transmitting.
KTTV channel 11 FOX.
KCOP-TV channel 13 MyNetwork.
KABC-TV channel 7 ABC.
KCAL-DT channel 9 IND.
Will most likely be received with a Winegard HD7698P antenna and a Antennas Direct CPA-19 preamp , aimed at about 280 degree magnetic compass direction.
And the Strong Digital Tv stations/channels of the opposite direction will be received through the back of the antenna.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box.
As always , trees and tree leaves do a real fine job of reducing or blocking reception and so do buildings and other obstructions.
It is best to install the antenna at a location that has the least amount to no amount of obstruction of any type or kind of the directions of reception.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named to 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
