Thread: No channels
Old 21-Sep-2012, 7:19 AM   #7
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
The South West group of digital Tv stations/channels.
As a Test of reception of the 1 strong Digital Tv station and the other weak Digital Tv stations.
WHVL-LD , REAL UHF channel 27 , MyNetwork and America One.
WATM-DT , REAL UHF channel 24 , ABC and FOX and This Tv.
WTAJ-DT , REAL UHF channel 32 , CBS.
WPSU-TV , REAL UHF channel 15 , PBS.
Aim the HD7698P antenna system at the south west group of tv stations at about 230 degree magnetic compass direction.
Rescan for the Digital broadcast Tv channels.
If the digital Tv stations/channels are received and you will like to continus to receive them.
Turn the HD7698P antenna system back around to the east.
And for reception of the south west group of Digital Tv stations/channels install a HD9095P antenna with a CPA-19 preamp , aimed at about 230 degree magnetic compass direction.
__________________________________________________
The 2 Tv antenna systems ate Not connected together on to 1 coax.
The 2 SEPARATE antenna systems are separate all the way to the locations of the Tv's and the 2 separate antenna systems are connected to a Remote control A/B antenna coax switch at each Tv location.
Here are the Remote control A/B antenna switches , http://www.radioshack.com , # 15-1968 , or , http://www.mcmelectronics.com , 32-4425 .
