Old 21-Sep-2012, 4:13 AM   #1
Souptown
Interested in giving OTA a try
I'm interested in moving from cable to OTA and have some questions.
First, could you please recommend an antenna based on this report:
http://www.tvfool.com/?option=com_wr...2df938566b7600
Second, I'd like to connect 3-4 TVs. From what I've been reading, I think I may need an amplifier. Is this correct?
Finally, I need some antenna mounting advice. I'm a renter, so I can't make any permanent alterations to the roof. I've got an existing dish mast on the South side of my home. Would this work? I'm inferring from the report that I would need to point my antenna North-ish. Would it be optimal for the antenna to have enough height to clear the top of the roof? I may be able to clamp a mast to the bathroom stack which is closer to the center of the roof.
Thanks in advance for any help.
Don
Souptown is offline   Reply With Quote
