Old 20-Sep-2012, 11:11 PM   #3
The following is a Teleview recommendation for broadcast Tv reception.
Antenna system number 1.
For reception of the local Canada broadcast Tv stations/channels.
Above the roof install and aim a ANT751 at about 35 degree magnetic compass direction.
The Canada Tv transmissions are Strong , no antenna amplifier required.
For 1 Tv connection use no splitter.
For 3 Tv's connected use a common simple 3 way splitter.
Some common above the roof antenna mounts are , tripod mount , eave mount , chimney mount.
____________________________________________________________
Antenna system numbers 1 and 2 are Not connected together on to one coax.
Antenna systems numbers 1 and 2 are SEPARATE complete antenna systems , the coaxes of each antenna system will go to each Tv location and be connected to , Remote control A/B coax antenna switch , http://www.mcmelectronics.com , #32-4425. http://www.saveandreplay.com , has the same A/B antenna switch.
Remote control A/B antenna switch is Channel Surfing Friendly , press the button on the remote control , change antennas and keep on channel surfing.
Antenna system number 2.
The American Digital Tv stations/channels.
WNLO-DT , The CW.
WVIB-DT , CBS.
WNYB-DT , Religion.
WNED-DT , PBS.
And the following weaker American Digital Tv stations/channels will most likely be received.
WUTV-DT , FOX and The Country Network.
WNYO-TV , MyNetwork.
WBBZ-TV , IND. , ME-TV and This Tv.
_______
Above The Roof at about 25 feet above ground , install a Winegard HD7698P with a Antennas Direct CPA-19 preamp.
Aimed at about 145 degrees magnetic compass direction.
As always , the starting antenna aim direction is the -> starting aim direction.
Turn/aim the HD7698P antenna for best reception of the listed American channels.
______
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.winegarddirect.com , http://www.antennasdirect.com , http://www.solidsignal.com , http://www.amazon.com.
