These and many more urban myths are what creates billions of layers of misinformation and straight out lies about Tv reception.
At least 99% of the humans are so full misinformation and lies that they do not know where the , begining is , whats in the middle , or where the end is.
Antennas and antenna amplifiers do Not 'pull in' Tv signals.
In general , the smaller the Tv antenna is , the less signal it will receive , the bigger the Tv antenna is the more signal will be received.
A Tv antenna is like a sail on a boat , a small sail will not receive as much wind as a big sail.
Sails do not 'pull in' wind and Tv antennas do not 'pull in' signals.
__________________________________________________________________
Signal amplifiers increase the strength of the signal but do not 'pull in' any signal or make any new signal.
It is not easy to explain , I use the ballon example.
A ballon in its un inflated state is the -> ballon.
Put air in the ballon and the ballon can do more and it is bigger , however it is still the same ballon.
______________
As for the antenna height , it is best to try the antenna at different heights , higher is not always automatic better.
According to the tvfool radar reports at 30 and 50 foot antenna heights WIAT is receivable with a reliable signal.
