Old 19-Sep-2012, 6:07 PM   #1
naturl
instalation and grounding
thanks to , groundurmast and teleview for their advice on purchasing a rca ant-752 antenna . I just received it and assembly is very easy but the base does not look like it will connect to the satellite mast [ direct tv ] , could someone suggest a way of doing this ? also what is the proper way to ground the antenna for static discharge and lightening ? I have a grounding rod just below the sat dish which is mounted on the roof .
thank you , naturl
naturl is offline   Reply With Quote
