Old 19-Sep-2012, 4:27 AM   #5
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
There is also CIMC-TV channel 10 , http://en.wikipedia.org/wiki/CIMC-TV.
This Tv station is at 232 degree magnetic compass direction.
As a Test.
The HD7082P or CM3679 antenna can be aimed at the Tv station , and scan for Broadcast Tv channels to see if CIMC is received.
If CIMC-TV channel 10 is received and has programing you will like receive , then turn the HD7082P/CM3679 back around to receive the other 3 Broadcast Tv stations.
________________________________
I recommend a Separate antenna for reception of CIMC , a Winegard YA1713 antenna and a Winegard AP8700 preamp or Channel Master CM7778 preamp , for reception of CIMC-TV channel 10
The YA1713 antenna system is SEPARATE from the other antenna system and is Not connected to the other antenna system.
With the YA1713 antenna system .
For 2 tv's connected use a , HFS-2D , 2 way splitter.
The 2 separate antenna systems are separate all the way to the location/s of the Tv/s and are connected to a Remote control A/B antenna switch , http://www.mcmelectronics.com , #32-4425 , saveandreplay also has this same remote control A/B antenna switch.
Two separate antenna systems with a remote control A/B antenna switch is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
