Thread: Antenna choice
Old 19-Sep-2012, 1:35 AM   #3
A Simple reception situation.
Install a Winegard HD7698P antenna with a Antenna Direct CPA-19 preamp aimed at about 330 degree magnetic compass direction.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com , http://www.solidsignal.com.
Here are some places to buy antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com.
______________________________
It is best to install the antenna at a location that has the least amount to no amount of any type or kind of obstructions in the direction of reception.
The Tv Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
