Old 19-Sep-2012, 12:43 AM   #4
The following is a Teleview recommendation for digital broadcast Tv reception.
A Simple reception situation.
The listed Digital Tv stations/channels , NBC , ABC ,
CBS , PBS , FOX , and , many , many , many , more will be received because the Tv signals are strong. The Digital Tv stations/channels list down to and including WRTN , Retro Tv Network and TUFF TV the Tv channel for Tuff men and PBJ and Classic shows - Movies.
Install a Winegard HD7694P antenna with no preamplifier above the roof aimed at about 20 degree magnetic compass direction.
The HD part of the HD7694P , means Heavy Duty.
For 1 Tv connection use no splitter.
Here are some Strong and Sturdy antenna mounts. http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
The ronard antenna mounts are heavy gauge alloy steal and put together with real heavy gauge nuts and bolts.
As always , trees and tree leaves do a fine good job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to locate the antenna at a location that has the least amount to know amount of obstructions of any type or kind in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
