Old 18-Sep-2012, 4:40 AM   #6
The following is a Teleview recommendation for broadcast Tv reception.
A Simple reception situation.
Above the roof or higher then the roof aim a Winegard HD7698P antenna with no preamplifier at about 0 degrees magnetic compass direction.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Triopods%200703/4712.html ,http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
