Old 17-Sep-2012, 11:22 PM   #2
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for Digital Broadcast Tv Reception.
A Simple reception situation for reception of the group of broadcast Tv stations/channels to the south , 180 degree magnetic compass direction.
Above the roof install a Winegard HD7698P antenna with no preamplifier aimed at about 180 degree magnetic compass direction.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are someplaces to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
