Old 17-Sep-2012, 9:43 PM   #6
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
I rarley use this word -> WOW , at 40 feet antenna height that made the Georgia , Digital Tv stations/channels Vary Receivable.
NBC , ABC , CBS , PBS , FOX , CW , MyTvNetwork , Me-Tv , and many more channels.
And the South Carolina Tv stations stayed about the same , weak signal strength.
I recommend aim the HD7698P antenna at Atlanta , about 275 degree magnetic compass direction.
And the Tv signals have increased to the point that can back down on the amplifier/booster.
With the stronger Tv signals I now recommend a Antennas Direct CPA-19 preamp.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
Buy the 2 way splitter at , http://www.hollandelectronics.com , or , http://www,solidsignal.com.
So thats HD7698P antenna and CPA-19 preamp at 40 feet above ground.
And with no trees or other obstructions , thats extra gravy on the mashed pottatos.
Here are some ways to get the antenna to 40 feet , http://www.3starinc.com/telescopic_masts_and_more.html.
Light weight , aluminum , free standing , lay over tower , Do all antenna installation and adjustments , Standing on the ground.
http://www.palcoelectronics.com/pe300.aspx.
