Old 17-Sep-2012, 5:56 AM   #4
Kinetic
Originally Posted by teleview View Post
One Tv antenna is preferd over using 2 Tv antennas for reception.
Here is a one antenna solution the can be expanded in to a 2 separate Tv antenna system by adding a second antenna if required.
Above the roof install a Winegard HD7000R antenna with a Antennas Direct CPA-19 preamp , aimed at about 160 degree magnetic compass direction.
For 1 tv connected use no splitter.
For 2 tv's connected use a , HFS-2D , 2 way splitter.
For 3 Tv's connmected use a , HFS-3D , 3 way splitter.
Here are places to buy the HFS splitters , http://www.hollandelectronics.com , http://www.solidsignal.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
This 1 Tv antenna set up is to receive the Current Plus Pending Applications Included Digital Tv stations/channels , in the tvfool channel list , down to and including WOAI-TV NBC. In the the Green and Yellow and Red reception zones.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstruction of all types and kinds in the directions of , north east , south east , south west.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
After reading about the Winegard HD7000R antenna I couldn't find what the range was. Will this antenna allow to receive broadcasts from up to 50 miles away?
Last edited by GroundUrMast; 4-Oct-2012 at 6:11 AM. Reason: Deleting off-topic content
Kinetic is offline   Reply With Quote
