->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation for broadcast tTv reception.
In hilly country , the strength of the signal at the reception location is often very sensative to the height and location of the receiving antenna , even 1 foot in change in antenna height or location can make the difference of reception and no reception.
Many times in hilly country , a lower antenna height can be better then a higher antenna height.
Go to the tvfool home page and click on >>StartMAPS<< , move the pointer to your Exact location , and change the antenna height.
The FOX signal strength of minus -11.2 NM(dB) shown in the tvfool report needs to be improved to a stronger signal strength.
At locations with Very weak signals , I pull out the big antenna gun.
I recommend a Winegard HD7698P antenna with a Winegard AP8700 preamp aimed at about 319 degree magnetic compass direction.
If you will send me a PM Private Message with your address or corodinates I will find the best antenna height/location for reception of FOX and the other channels.
