Old 16-Sep-2012, 8:27 AM   #4
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
To make the following recommendation work , The antenna must be installed above the roof.
The Tv Digital Tv transmissions are Strong at your location in the Green and Yellow reception zones.
Except for ,
WNCR -LD REAL UHF channel 41 , http://americaone.com.
WHIG-LD REAL UHF channel 31 , http://www.whigtv.com.
WUVC-DT REAL UHF channel 38 Univision.
The antenna is aimed more in favor of , WNCR and WHIG , to make the reception stronger.
I Think that 1 Tv antenna will provide reliable reception of the many digital Tv stations/channels of multipul directions of , west , north west , north , north east , south east.
Install a ANT751 antenna Above The Roof aimed at about 346 degree magnetic compass.
The ANT751 receives good at , front , front angles , back , back angles.
Solidsignal has a ANT751 antenna with a J type antenna mount , low dollars.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
For one Tv connection use no splitter , no amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
