Old 16-Sep-2012, 2:37 AM   #7
The following is a Teleview recommendation for broadcast Tv reception.
No less the 25 feet above ground , install a Antennas Direct DB4e antenna aimed at about 120 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
And install a Antenna Craft CS600 aimed at about 95 degree magnetic compass direction.
Connect the 2 antennas together with a UVSJ = UHF/VHF Separator/Joiner.
Type these letters -> uvsj , in the , http://www.solidsignal.com , search box.
For 1 Tv connected use no splitter , use no amplifier.
For 2 Tv's connected use a Channel Master CM3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.antennacraft.net.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcas Tv Channels , sometimes named the 'Air Channel' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
