Old 15-Sep-2012, 11:30 PM   #3
The following is a Teleview recommendation for broadcast Tv reception.
Antenna system number 2.
Aim a Winegard HD 7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 342 degree magnetic compass direction.
For 1 Tv connected use no splitter and no amplifier.
_________________________________________________________________
2 Separate antenna systems are Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
Antenna systems numbers 1 and 2 are not connected on to one coax.
The 2 antenna systems are Separate all the way to the locations of the Tv's.
The 2 Separate antenna systems are connected to a Remote control A/B coax antenna switch at each Tv location. http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
Is Ok to install 1 antenna system to begin with , Deltona/Orlango has many more Digital Tv stations/channels then Jacksonville.
Using a Antenna with a Rotator is Not Channel Surfing Friendly , must wait for antenna to rotate , and not every one in the house will agree on where the antenna is aimed.
