Old 15-Sep-2012, 5:12 PM   #2
The following is a Teleview recommendation for broadcast Tv reception.
A Simple reception situation.
The antenna Will Not be in the attic.
Above The Roof , install a Clear Stream 2 Complete UHF/VHF antenna aimed at about 315 degree magnetic compass direction.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Remove the - reflector screen - from the CS2 Complete so the antenna will receive both directions , Richmond and Charlottesville Digital Tv stations/channels.
For 1 Tv connected use no splitter , use no amplifier.
For 2 Tv's connected use a , Channel Master CM 3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM 3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/9809911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including you own house.
It is best to install the CS2 Complete at a location that has the least amount to no amount of obstructions of any type or kind of obstructions in the directions of reception to the north west and south east.
