Old 15-Sep-2012, 4:31 AM   #1
Kinetic
Antenna/Amp advice
I've been using an OTA setup since 2007, and until now I've always been <10 miles from the broadcast towers in San Antonio, TX. I moved out to Boerne, TX which puts me about 45 miles from the broadcast towers I was picking up. Here is my tvfool signal analysis:
http://www.tvfool.com/?option=com_wr...5ed67c56d51710
My previous antenna was damaged in the move, so I'm looking to pick up a new one along with an amp if necessary. I'm still quite green when it comes to the actual science of it all (living 10 miles from the towers was basically plug-n-play).
I would appreciate any help or advice. I'll be mounting the antenna on the side of my house/roof and it will probably be about 15-20ft up.
Thanks in advance!
Kinetic is offline   Reply With Quote
