Thread: Zero channels
Old 14-Sep-2012, 4:45 PM   #5
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
Above The Roof , at no less then 20 feet above ground and 40 feet is better , install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 313 degree magnetic compass direction.
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/Tripods%200703/4712.html.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best locate the antenna at a location that has the least amount to no amount of trees and tree leaves and buildings or other obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
