Thread: YA-1713 Stacked
Old 13-Sep-2012, 7:34 PM   #6
Originally Posted by cheap View Post
How can I improve reliability of channel 8???
I assume that there are no trees or houses between your antenna and the water. If so, find a location that's clear.
Next I'd be considering a taller mast. The goal is to match the antenna height to the slightly sloping terrain toward the water to make the lowest lobe at zero degrees.
http://www.qsl.net/oz1rh/gndgain/gnd_gain_eme_2002.htm
If a taller mast is not feasible for you, consider a box of 4 VHF antennas.
