Is it because I'm pointing directly at KDKA (138*)?
Perhaps. It depends on WHICH WNEO signal you're getting.
At about 90° off boresite and assuming you're getting WNEO's signal from their primary tower, most Yagi-style antennas such as the 91XG are about as blind as a bat by design.
TVFool does show that WNEO operates a channel 44 translator overlooking Youngstown. If you're getting that one, it's coming in off the back of the 91XG and may be suffering severe degradation.
Can you check to see which WNEO you're getting?
