An RCA ANT-751 is a compact antenna that is worth considering. If mounted high enough to 'see' over the roof, it will do well in the conditions shown in your report. I would try pointing south to begin with, the weaker signals will be more reliable. At the same time, the stronger signals from the NW will still be received. Of course, it pays to experiment with aim, with the signals coming from so many directions you'll be looking for the best compromise rather than focusing on just one signal.
