Our neighborhood is a block of flat row houses. No trees above the roofline.
No ghosting in the past.
Thinking of mounting the MS-1000 on a chimney mounted mast.
Its data sheet says it needs to be rotated for best reception. Any experience with them?
Otherwise it may come to down to what's available locally, or fastest/cheapest, if I have to order.
Channel Master lists the CM-3016 for channels 2 thru 69.
Perhaps they revised it.
Now to try to find one locally, someone to install it.
$200 doesn't even come close to paying for a hospital stay.
