Simple, effective DTV reception solutions.
Use the DB4 that you have. Add an Antenncraft Y5 7-13 high VHF antenna on the same mast with 18" of seperation between the antennas (less than $25) and use a Winegard AP 2870 amplifier. This has seperate U/V inputs and will combind the two antennas into one output.
Use a Eagel Aspen Roto 100 rotor. This rotor will run off of the signal coax provided you use the recommended amplifier and follow the manufactures instructions for single wire configuration.
When installing, aim the antenna and rotor to magnetic North and you can use the rotor display to aim to the magnetic locations of all of your stations.
You will receive more stations more reliably with this configuration.
