Old 11-Sep-2012, 4:04 PM   #4
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
It is amazing , the Resistance , to taking even simple action to get Tv reception.
There are no magic Tv antennas.
There are no magic reception situations.
_____
If there are any of those small satellite dishes on the outside , how do the coax cables get from the satellite dish to the receiver on the inside????
Through a hole through the wall????
And how does the cable tv company add a extra cable outlet to an other room??
Is it with coax on the outside of the building , and then the coax goes through a hole through the wall in to the room????
________________________________________
Did you read the part about the flat coax?? . The flat coax is not the first choice to get the coax from point A to point B.
As a test of reception , It is OK to run a coax through the - open - balcony door.
As you can see on the the tvfool radar map , The main groups of digital Tv stations are to the South East.
On the balcony , Above the balcony wall , aim the FV-HD30 to the South East.
Adjust the aim for best reception.
______________
_____
It is best to have the antenna at a location that has the least amount to no amount of obstructions to the South East.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , some times named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
