The following is a Teleview recommendation for Digital Broadcast Tv Reception.
For more strength and duribility.
Above the roof install a Antenna Direct , Clear Stream 4 and a Antennas Direct C5 antenna , both aimed at about 76 degree magnetic compass.
The C5 comes with a combiner to connect the CS4 and C5 together on to one coax down lead.
For 1 Tv connected use no splitter no amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 or 4 Tv's connected use a CM3414 distribution amplifier.
_________________________________________________________
If your house has a chimney , can tie a , long , pole or pipe to the chimney as a temporary way of testing reception , can give a idea of how high or low will have to go for reception.
The more distance away the trees are in the direction of reception the better.
If there is a opening in the trees in the direction of reception , that's better.
___________________________________________________________________
