Old 11-Sep-2012, 5:52 AM   #2
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadecast Tv reception.
A Simple reception situation.
Above the roof install a Winegard HD7696P antenna aimed at about 76 degree magnetic compass direction.
For 1 tv connected use no splitter no amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmaster.com.
It is best mount the Tv antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
