Thread: Antenna Help
Old 9-Sep-2012, 1:50 AM   #3
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
Antenna system number 2.
Canada Tv stations/channels.
As a Test of reception , aim the HD7696P antenna at about 325 degree magnetic compass direction.
Rescan for Digital Broadcast Tv stations/channels.
CBET-DT Digital VHF channel 09 , CBC.
CICO-DT Digital UHF channel 32 , TVO.
CHWI-DT Digital UHF channel 16 , CTV.
If reception is Ok with no signal dropouts.
Turn antenna system number 1 antenna back around for reception of the American Digital Tv stations/channels.
_________________________________________
Install a second HD7696P antenna with a CPA-19 preamp and etc.. the same as antenna system number 1 for reception of the Canada Digital Tv station/channels.
Antenna system number 1 and 2 Will Not be connected together on to one coax.
The antenna systems and coaxes are Separate all the way to the TV/s.
At each Tv location will be a Remote control A/B coax antenna switch connected to separate antenna systems coaxes.
And the output of the A/B switch is connected to Tv.
A/B antenna switching Is Channel Surfing Friendly , push the button on the hand held remote control , change antenna systems and keep on channel surfing.
http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425.
