Thread: Antenna Help
Old 8-Sep-2012, 11:17 PM   #2
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
Antenna system number 1.
A Simple reception situation.
Above the roof install a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp aimed at about 150 degree magnetic compass direction.
For 2 tv's connected use a HFS-2D , 2way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at soldsignal by typing the word ronard in the solidsignal search box.
It is best to locate a antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
