Old 8-Sep-2012, 10:02 PM   #5
I can not say how many Digital Tv stations/channels will be received.
A better antenna to use is the Antennas Direct , Clear Stream 2 Complete UHF/VHF antenna with a Antennas Direct CPA-19 preamp.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Most likely , up high will provide the best reception , test locations for best reception.
The best way to get the coax from the balcony to in side the apartment is a hole through the wall.
Here is an other way to do it. Flat Coax , Eagle Aspen FC-300LX , http://www.solidsignal.com.
It is best to locate the antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
