Thanks for the tips. At the moment I am only connecting 1 tv to the antenna. The wire feeds from the attic down into a structure wiring panel, from there I can connect it directly to the wire in the tv room.
Just curious why you recommend 138 instead of 164? Trying to learn as I read more here.
If I'm stuck on attic vs. roof installation do try the ANT model or do I need to think about moving up to a larger yagi?
