Old 8-Sep-2012, 6:27 AM   #1
thor620
New OTA Setup Help Needed in Phoenix
http://www.tvfool.com/?option=com_wr...e779c201db4000
Trying to switch from Cable to OTA, looking to use the antenna signal to feed my Tivo Premier.
I originally, naively, started with a simple flat multi-directional antenna hung on the wall next to my tv. When that didn't pull in much I started doing some research and found tvfool. Learning that I was 30 miles from all the towers with some obstruction (pretty sure it is a hill/mountain south of me) I returned it and picked up an RCA ANT 751. Was hoping that this would be enough to pull in what I needed. If can get get the major networks and PBS from the tower cluster at 164 degrees I'd be a happy camper.
My preference is to install the antenna in the attic, I know I've read all the recommendations here suggesting otherwise, but my attic is pre-wired by the builder with a coax run already and to be honest I'm just not up for crawling on the roof to mount this thing. Roof construction is concrete tile.
I'm starting to play with the RCA in the attic now and wondering if it is not enough antenna or if my desire to have the setup in the attic is just never going to work because of my distance/obstruction between me and the tower.
I know the meter levels are subjective, but I can't get better than 66% on the unit's signal meter when I point the antenna to 164 degrees and bring it up as high as I can inside the attic space. Am I asking too much of the RCA unit I have? Do I need to upsize the antenna to get a bit stronger signal/consistency or do I need to re-think the whole attic plan?
Thanks for any help/wisdom you can share!
thor620 is offline   Reply With Quote
