Old 8-Sep-2012, 4:43 AM   #2
The following is a Teleview recommendation for digital broadcast tv reception.
A Simple reception situation.
Above the roof install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 260 degree magnetic compass direction.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
It is best to install the antenna in a manner that has the least amount to no amount of trees or obstructions in the direction of reception.
