Old 8-Sep-2012, 12:29 AM   #10
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
Antenna System Number 2.
For reception of ,
WCML REAL Digital UHF channel 24 , virtual number (6.1) PBS.
WFUP REAL Digital channel 45 , virtual number (45.1-2) FOX and CBS.
Above the roof install a Antennas Direct DB4e antenna with a Antennas Direct CPA-19 preamp , aimed at about 155 degree magnetic compass direction.
For one Tv connected use no splitter.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
_______________________________________________
Antenna systems 1 and 2 are Not connected together on to one coax.
Antenna systems 1 and 2 are Separate antenna systems all the way to the location/s of the Tv/s.
At the location/s of the Tv/s will be a Remote control A/B antenna coax switch that is connected to the Separate antenna systems coaxes and then to the Tv.
http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
Remote control A/B antenna switches are Channel Surfing Friendly , press the button on the hand held remote control , change antenna systems and keep on channel surfing.
It is best to locate the antenna/s at a place where there is the least amount to no amount of obstructions in the direction/s of reception.
