Old 7-Sep-2012, 7:07 AM   #4
The following is a Teleview recommendation for digital broadcast Tv reception
The flat antennas are not good antennas for Tv reception.
I say the flat antennas are made for only one reason , to transfer money from your pocket to some one else pocket.
The radio shack antenna with the 12 position "fine tuning' switch ,
What the 'fine tuning' switch does is connect the VHF channels metal reception rods and the UHF channels metal reception loop that is inside of the plastic housing , in different combinations as the switch is turned from one position to the next.
The down side is , it is next to impossible to find a switch position that will receive all channels with out changing the switch position.
If you have no choice but use one of the antennas , then use the radio shack antenna.
Put the antenna in a west facing window.
If required use a long coax to connect the antenna to the Tv.
Aim the antenna at about 250 degree magnetic compass direction , south west.
Here is how to aim indoor type antenna. http://www.kyes.com/antenna/pointing/pointing.html.
The rods of the antenna are extended and adjusted to a wide spread low vee position and aimed broad side at about 250 degree magnetic compass direction , south west.
As an example , extend your arms straight out from the sides of your body , move your arms up a little to make a low vee , now face the south west , aim the antenna the same way.
A much better indoor antenna to use is TERK HDTVi.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
