Old 7-Sep-2012, 4:40 AM   #1
brandonb
Looking for a new antenna setup
Hello fine people of TV Fool,
Firstly, I have no idea what I'm doing when it comes to this stuff. However, I am technically inclined (I'm a computer builder/enthusiast), if that makes any difference.
Here are my Signal Analysis Results. I only care about the first 20 - 25 channels. My current setup is a Winegard SS-3300, up in the attic and split 2 ways. It's approximately 30 feet (could be higher) from ground level.
Now a frustrating problem I have. My mom gets 19 digital channels on her TV downstairs. I however only get 11 channels on my TV on the third floor (much shorter run from the antenna). Why is this? All the channels she gets come in crystal clear, so there's no reason I can think of that would prevent me from getting the same amount of channels she does.
I considered that perhaps it was a problem with the tuner it self, however my live TV dongle for my Boxee Box behaves the same way.
The above is the main reason I want to get a better antenna, or should I say, an antenna more suited for my needs. From what I can tell, most of the channels I want are UHF, so I couldn't care less about the VHF channels.
If I'm not mistaken (and I could be), our roof is a single layer of shingle, sheet metal under that and the frame and everything else is wood. Attic mount is my only option.
I'm not sure how much information you guys need, so just let me know if I'm missing anything.
Thank you!
Edit:
Also, we do not have cable or satellite TV.
brandonb is offline   Reply With Quote
