ALL questions and answers about broadcast tv reception and More.
The following is a Teleview - recommendation for broadcast Tv reception.
Splitters DO NOT DEGARDE the signal.
Splitters , split the signal to other locations.
Splitters reduce signal level by maximum of 3.5 dB for each split.
Here is the TRUTH , the signal strengths will supply signal to signal to 2 , 3 , 4 , TV's when using the DB4e antenna.
Here is the TRUTH , use a common simple 2 way splitter.
Here are some but not all common simple splitters ,
P-1000-2AP-GX , CM3212 , RCAVH47 , GE 73218 , CNC2002H , DIG702867 .
________________
Gold Plated Super Wiz Bang , Certified Digital , 0 to 4500 Mhz splitters , at 50 dollars a Pop are not required.
