Old 6-Sep-2012, 8:18 AM   #2
The following is a Teleview - recommendation for digital broadcast Tv reception.
North west direction has the most Digital Tv stations/channels.
Many Digital TV stations/channels will be received.
Aim a Winegard HD7084P antenna with a AP8275 preamp at about 328 degree magnetic compass direction.
For 1 Tv connection use no splitter.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com or http://www.solidsignal.com.
_________
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to install a antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna,
