Old 6-Sep-2012, 2:23 AM   #2
The following is a Teleview - recommendation for broadcast Tv reception.
Antenna system # 1.
For reception of the Digital Tv station/channels in the Green and Yellow reception zones of the tvfool channel list to the north east.
Instal a Winegard HD7696P antenna with no preamp aimed at about 65 degree magnetic compass direction.
For 2 tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
It is best to install a Tv antenna at a location that has the least amount to no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
