Thank you all. I have the DB4e, a 30' quad-shielded RG6, and a Ronard chimney mount in my cart at SolidSignal. I assume I can simply source a length of 1" pipe from a local hardware store to use for the antenna mast. Are there any recommendations for that pipe that make it better to use for this application?
Because my chimney is on the north side of my house, and does not extend above the top ridgeline of the roof, I will probably be mounting a pole that extends about 10-12ft ABOVE the top of the chimney. Which will put the antenna about 28'-30' above ground level. For a pole this tall, should I plan to use anything else besides the chimney mounts? It seems like a guide-wire or something of the sort might be necessary.
