The following is a Teleview - recommendation for broadcast Tv reception.
Quote.
The DB4e will receive channel 7 signal that is Very Strong and act to attenuate the channel 7 signal strength.
That being the case , then all of the channels are received , The VHF high band channel 7 , the VHF high band is channels 7 thru 13.
And the UHF channels , the UHF channels are 14 thru 51.
____________________________________________________
If you are connecting more then one Tv , you can connect the little RCA antenna to a splitter and see if it will supply signal to all Tv's.
You say the little RCA antenna is working well.
If you like you can connect a indoor antenna to each Tv , You can get some more of the little RCA antennas.
Or I recommend the TERK HDTVi.
