Rural install help
Looking for setup recommendation. Got 8.1, 8.2 and 8.3 only using a standard outdoor antenna mounted 20 feet up using a signal amp from Walmart. I attached a location map. Dfw is 66 miles away. I am surrounded by trees. Antenna amp and pole height help is appreciated. The 8.1 picture was fantastic. 37 percent signal strength.
