The following is a Teleview - recommendation for digital broadcast Tv reception.
KQTV is a strong signal , I recommend install a Antennas Direct DB4e UHF antenna (no amplifiers) to receive the UHF stations and the Weak KSHB-TV UHF channel 42 NBC.
The DB4e UHF antenna will receive the channel 7 signal that is very strong and act to attenuate the channel 7 signal strength.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
No requirement for UVSJ's and second antennas and such.
Aim the DB4e at about 175 degree magnetic compass direction.
Here is how to aim antennas ,
Here are some above the roof antenna mounts ,
http://www.ronard.com/909911.html ,
http://www.ronard.com/34424560.html ,
http://www.ronard.com/ychim.html ,
http://www.ronard.com.
Here are some places to by antennas and etc. ,
http://www.solidsignal.com ,
http://www.amazon.com.
It is best install the antenna at a location where there is the least amount to no amount of trees and obstructions in the directions of reception.
