Thread: PBS in Atlanta?
Old 4-Sep-2012, 5:23 PM   #2
The follwing is a Teleview - recommaendation for digital broadcast Tv reception.
A Simple reception situation.
Above the roof install a ANT751 antenna , with No preamplifier , aimed at about 290 degree magnetic compass direction.
http://www.solidsignal.com , has the ANT751 Antenna with a J Type Antenna Mount for low dollars.
For 1 Tv connection use splitter.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the transmissions travel through the air from the transmitting antenna to the receiving antenna.
