Old 2-Oct-2010, 4:19 PM   #5
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Forget the two-antenna system: way too cumbersome and totally unnecessary! use a single Winegard HD-7696P on top of a Channel Master 9521a rotator. Under most circumstances, you will be able to aim the antenna at 340 degrees and see both DC and Baltimore from your location. If you need to pinpoint aim the antenna to sharpen your reception, the rotator will allow you to do so.
You didn't mention how many TV sets you plan to use, but you may want to add a high-input preamplifier like a Winegard HDP-269 if you want to split the signal to more than 2 TV sets.
